Til sölu Lamptron 10" HM101 hardware monitor HDMI skjár
Fletch
Póstar: 1203
Staðsetning: MHz=MHz+1
Pósturaf Fletch » Mán 13. Sep 2021 13:38
Til sölu Lamptron HM101 hardware monitor HDMI skjár, 10" USB powered. Hugsað sem stöðuskjár inní kassa t.d., taka info úr AIDA64 eða slíku forriti
https://www.overclockers.co.uk/lamptron ... 0w-lp.html
Gekk ekki í project sem ég var með þannig hann er til sölu, ónotaður, hægt að nota hann bara sem venjulegan HDMI skjá líka
PRODUCT INFORMATION:
HM101 10" SCREEN HARDWARE MONITOR
AIDA64 statistics can be displayed on this IPS monitor. It offers convenient hardware monitoring in real time on a 10-inch screen diagonal. Thanks to the included bracket, it can be placed on a table, on the wall or inside a correspondingly large housing with a transparent side panel.
The features of the Lamptron HM101 hardware monitor at a glance:
- External IPS monitor with 10 "diagonal
- Developed through close collaboration between Lamptron and AIDA64
- To view AIDA64 statistics and information
- Screen resolution: 1,920 x 1,080 pixels @ 60 - 75hz
- Including holder for placement on the desk, on the wall or in the PC case
- Customizable user interface with different designs
The features of the Lamptron HM101 hardware monitor in detail
With the HM101 monitor from Lamptron , the hardware statistics of the AIDA64 monitoring software can be displayed. The external 10-inch IPS monitor was created through close collaboration with the AIDA64 software team and allows real-time monitoring of the PC hardware without having to sacrifice space on the main screen.
The display offers a resolution of 1,920 by 1,080 pixels with a 60hz refresh rate . It can be easily placed on the desk, on a wall or inside the computer using the bracket supplied. The user interface can be customized, for which Lamptron provides several design sets.
Technical details:
- Dimensions: 242 x 160 x 12.5 mm (W x H x D)
- Screen size: 219 x 139 mm (W x H)
- Viewing angle: 178 °
- Colour: Black
- DC input: 5 V (USB)
- Connections: HDMI, Micro-USB
Verðhugmynd 25þ
Áhugasamir hafi samanband
Síðast breytt af Fletch á Sun 29. Ágú 2021 20:45, breytt samtals 1 sinni.
Síðast „Bumpað“ af Fletch á Mán 13. Sep 2021 13:38.
AMD Ryzen 5900x * Nvidia GTX 3080 * Asus ROG Crosshair VIII Hero * 32GB DDR4 Samsung B-Die @3800MHz (14-14-14-28)
Watercooled * CaseLabs T10 * Corsair HX 1200i * LG 38GL950 * Windows 10 Ent x64
