[Selt] GeForce® GTX 1070 WINDFORCE OC 8G
Verisan
Póstar: 167
Skráði sig: Sun 20. Sep 2009 10:53
Pósturaf Verisan » Fös 10. Des 2021 20:44
Er með til sölu GeForce® GTX 1070 WINDFORCE OC 8G
Keypt notað af vaktinni fyrir nokkrum árum.
Ætla að setja á það 35 Þ. eða hæðsta boð.
Áskil mér rétt til að hætta við sölu.
Komið boð upp á 36 Þ.
https://www.gigabyte.com/Graphics-Card/ ... -rev-10#kf
GTX 1070.JPG (58.32 KiB) Skoðað 541 sinnum
Features
Power by GeForce® GTX 1070
Integrated with 8GB GDDR5/ 256bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
Build with 6+2 power phases
Core Clock
Boost: 1771 MHz/ Base: 1582 MHz in OC Mode
Boost: 1746 MHz/ Base: 1556 MHz in Gaming
Graphics Processing
GeForce® GTX 1070
Core Clock
Boost: 1771 MHz / Base: 1582 MHz in OC mode
Boost: 1746 MHz / Base: 1556 MHz in Gaming mode
CUDA® Cores 1920
Process Technology 16 nm
Memory Clock 8008 MHz
Memory Size 8 GB
Memory Type GDDR5
Memory Bus 256 bit
Card Bus PCI-E 3.0 x 16
Digital max resolution 7680x4320
Multi-view 4
Card size H=37 L=280 W=131 mm
PCB Form ATX
DirectX 12
OpenGL 4.5
Recommended PSU 500W
Power Connectors 8 pin*1
Output Dual-link DVI-D *1
HDMI-2.0b*1 (Max Resolution: 4096x2160 @60 Hz)
Display Port-1.4 *3 (Max Resolution: 7680x4320 @60 Hz)
SLI Support 2-way SLI HB
Síðast breytt af Verisan á Mán 13. Des 2021 16:22, breytt samtals 3 sinnum.
P4 @ 1,5 GHz | Msi 845 Pro Socket 423 | 2x256Mb og 1x512Mb@ 133MHz | Nvidia GeForce4 MX 420 64 MB | Samsung SP1614N| Sennheiser HD430 | Logitech Cordless Desktop Pro og Mouse Man|Win XP Pro |Sampo 19" |
