Battlefield demo - virkar ekki
Höfundur - Internetsérfræðingur
- Póstar: 6835
Þegar ég fer í demoið kemur bara svartur skjár og svo aftur desktoppið...
vot sjúld æ dú?
vot sjúld æ dú?
- Póstar: 6835
hahallur
Gestir
- Póstar: 6835
gætir þurft að breyta Hz og eitthvað svaka....leiðbeiningar hér:
I fount a way to fix the exit after 10 seconds of black screen problem!
Open Video.con inside:
"My Documents\Battlefield 2 Demo\Profiles\Default\"
Change Line:
VideoSettings.setResolution 800x600@60Hz
Change this line to for example if you are using:
1280x1024 @ 85Hz refresh rate:
VideoSettings.setResolution 1280x1024@85Hz
1024x768 @ 85Hz refresh rate:
VideoSettings.setResolution 1024x768@85Hz
1024x768 @ 75Hz refresh rate:
VideoSettings.setResolution 1024x768@75Hz
800x600 @ 85Hz refresh rate:
VideoSettings.setResolution 800x600@85Hz
Just try all resulutions and refresh rates!
If this doesn't work for you make sure that inside Battlefield 2's folder that in the file VideoDefault.con that renderer.allowAllRefreshRates is set to 1 not 0
zaiLex
- FanBoy
- Póstar: 724
- Skráði sig: Fim 30. Okt 2003 01:46
gnarr skrifaði:djöfull er ég orðinn fokkin ógeðslega pirraður á þessu demói! Ég er búinn að bíða í 10x 20mínútur eftir að þetta helvíti loadist, og ég dett alltaf útur þessum helvítis leik. hvað er annars fokkin málið með fokkin hálf´tima load tíma!![]()
http://www.tweakguides.com/BF2_1.html
Loading Issues: The most common problem with BF2 is that the game crashes to desktop or goes to a black screen when you first launch it. The reason for this is either incompatible hardware (make sure you meet all the minimum specs), or more usually the fact that you're not running at the default Windows XP refresh rate (60Hz). By default the game tries to launch at 800x600@60Hz initially, so your system must be able to run that same resolution and refresh rate, otherwise the game will abort. If you are using any refresh rate override program/method, disable it (e.g. if you're using Refresh Force, click the 'Restore Original Settings' button and apply). Once you've got the game running, you can then change the resolution to suit your taste in the in-game settings, and importantly you can select a higher refresh rate. Then you can reapply the refresh rate override and the game will launch without any problems.
Macbook Pro M4 Pro 14" 48GB 1TB
Snorrmund
- Of mikill frítími
- Póstar: 1825
- Skráði sig: Lau 04. Jan 2003 22:10
Ha? afhverju ættiru að vera með fleiri en eitt hljóðkort? ertu kannski með heimastúdío eða eitthvaðgnarr skrifaði:jæja.. ég komst að því að leiknum fannst ég vera með of mörg hljóðkort.. ég þurfti bara að disable-a eitthvað hljóðkort í tölvunni minni og þá virkaði leikurinn. Það skipti engu máli hvaða hljóðkort það var
- Póstar: 6835
OHH!!
Er búinn að spila BF2 demo í tvo daga, en í dag þegar ég er búinn að loada mappinu get ég ekki hreyft músina og lyklaborðið virkar ekki!! Búinn að prufa að re'installa en það virkaði ekki!
Hellp mí pLýs
Hellp mí pLýs
