Veit einhver hvar ég get keypt langann IDE 100/133 kapal, allavegana 60 sm, ekkert endilega round.
Veit að það er til í Tölvulistanum en hann kostar bara 4000kr
IDE
- spjallið.is
- Póstar: 473
- Skráði sig: Fim 26. Sep 2002 20:37
- Staðsetning: Hef ekki glóru!
RECOM round cables
ATA100 90cm
for 2xATA66/100, fully molded, movable endcaps, twisted, high quality tubing
á 1990 kall á http://www.task.is
ertu ekki annas að meina þetta?
ATA100 90cm
- spjallið.is
- Póstar: 435
- Skráði sig: Mið 25. Sep 2002 14:27
- Staðsetning: Keflavík
já mig vantar svona líka en mér líst betur á þennan sem http://www.task.is er að selja þeir eru bæði ódýrari og lengri og þeir eru round
kv,
Castrate
Castrate
- Gúrú
- Póstar: 573
- Skráði sig: Þri 24. Sep 2002 16:48
- Staðsetning: Reykjavík
sjá http://www.tweakers.com.au/articles/sto ... /page6.asp
Negligible = Not significant or important enough to be worth considering; trifling. - http://www.dictionary.com
Það ætti ekki að skipta neinu máli hvort þú kaupir 100 eða 133 kapla túlka ég út úr þessu, þar sem munurinn á þessu sé óverulegur.
Conclusion
The results may vary between drives, but the difference in performance from ATA100 and ATA133 is negligible. In some instances the results were very close, while in others like the High-End Winmark tests mode 6 DMA took the lead. I was also quite surprised to see that ATA133 was actually beaten in the HD Tach tests when in ATA100 mode. ATA133 should theoretically be 33% faster than ATA100, but my results basically didn't show much of an improvement at all. If you're thinking about upgrading a single drive from ATA100 to ATA133, I say keep you cash and wait for something better - there's always SCSI too! Keep that main idea behind ATA133 is minimise bottlenecks in the system when your running MORE than one drive, and to allow manufacturers to build drives larger than 120GB.
