[SELD]Samsung ST90 14.2 MP
Zorky
Póstar: 492
Skráði sig: Lau 10. Júl 2004 18:54
Pósturaf Zorky » Sun 10. Nóv 2013 16:42
Er að selja sirca 1-2 ára gamla myndavél keifta í Bretlandi hún er notuð en vel með farin, það fylgir hulstur með kassnum og bækling ásamt hleðslutæki með íslensku millistykki, það er eining hægt að hlaða hana í gegnum usb á tölvunni það fylgir snúra fyrir það
fer á 5000 kr :)
Hér eru samt upplýsingar um myndavélina og eiginleikar.
Product Description
Color: Indigo Blue
From the Manufacturer
Capture those special moments with the Samsung ST90 14.2-Megapixel Digital Still Camera. With HD Movie, you can record high-definition video. The camera comes equipped with a 26mm wide-angle Samsung lens, a 5x optical zoom, and Intelli-Studio software that lets you play, edit, and share files on your PC. Samsung's Smart Auto 2.0, Beauty Shot, and Smart Crop features make creating perfect photos easy.
callout top with logo
ST90 Digital Still Camera (Indigo Blue)
At a Glance:
14.2-megapixel digital camera with 5x optical zoom provides great image quality
Records HD video in 1,280-by-720-pixel resolution
Smart Auto feature analyzes composition elements to create the perfect shot
3-inch LCD for easy navigation of settings
Intelli-Studio 2.0 software lets you play, edit, and share files on any PC
One-year limited warranty on parts and labor
callout bottom
Samsung ST90 14.2 Megapixel Digital Still Camera (Indigo Blue) Product Shot
Features a 26mm wide-angle lens with 5x optical zoom for high-quality expansive shots. View larger.
3-inch LCD lets you review and navigate through shots with ease. View larger.
(shown in silver)
Digital Image Stabilization for Sharp Images and Video
Make sure the only motion in your videos is intentional. Digital image stabilization automatically compensates for unwanted camcorder movement by realigning each electronic image, frame by frame, with steady results.
The Samsung ST90 allows you to record movies in the palm of your hand. With HD Movie, you can capture video in 1,280-by-720-pixel resolution at 30 frames per second.
Play, Edit, and Share Files with Intelli-Studio
The Samsung ST90 comes with Intelli-Studio 2.0, easy-to-use software that allows you to play, edit, and share image and video files on any PC. Plug the camera into your computer using the USB input, and the software starts up automatically.
Smart Auto 2.0 Creates the Perfect Shot
Using Smart Auto 2.0, the Samsung ST90 captures the perfect shot by analyzing key composition elements and selecting from 15 different photo and 4 different movie modes.
Thanks to its face/smile/blink-detection feature, the Samsung ST90 detects and adjusts the lighting on up to nine different faces at a time. The camera will automatically shoot the subjects when they laugh or smile, and prohibit the shot from happening if anyone's eyes are closed.
Advanced Effects for High-Quality Photos
The camera's Beauty Shot feature automatically removes dark circles, facial blemishes, and imperfections to create great portraits. It's like having a makeup artist in your camera.
After shooting an item at an angle, use the camera's Smart Crop feature to alter the image to appear as if it were shot straight on. Simply select four crop points on the image, and it automatically reappears, re-cropped in full frame, from the desired angle.
Easy Navigation with 3-Inch Color LCD
See everything you're recording with the 3-inch color LCD display, which gives you a crisp, clear picture with natural color and dynamic detail. This beautiful display provides comfort and confidence in any external light condition. The touch panel feature makes menu navigation a breeze, so you'll quickly have the settings you want for every shot.
Product and Warranty Information
The Samsung ST90 is equipped with a 26mm wide-angle Samsung lens, a 5x optical zoom, and a 3-inch LCD. It offers 32 MB internal memory, and accepts external microSD cards up to 2 GB and external microSDHC cards up to 8 GB. The camera measures 2.2 by 3.7 by 0.8 inches (H x W x D) and weighs 0.23 pounds.
The Samsung ST90 is backed by a one-year limited warranty on parts and labor.
What's in the Box
Camera, AC adapter/USB cable, rechargeable battery, strap, Intelli-Studio 2.0 software, user manual CD-ROM, and quick start manual.
Product Description
16.5mm slim design with 5X zoom
Síðast breytt af Zorky á Mán 02. Des 2013 08:04, breytt samtals 6 sinnum.
Zorky
Póstar: 492
Re: [TS]Samsung ST90 14.2 MP
Pósturaf Zorky » Mán 11. Nóv 2013 11:50
Nýtt verð fer á 10.000kr
Zorky
Póstar: 492
Pósturaf Zorky » Þri 12. Nóv 2013 11:59
bömp :)
Zorky
Póstar: 492
Pósturaf Zorky » Lau 16. Nóv 2013 12:21
Upp með þetta gott tilboð hér á ferð :)
Zorky
Póstar: 492
Pósturaf Zorky » Mið 20. Nóv 2013 09:58
Upp með þetta, bæta við það fylgir leður taska :)
Zorky
Póstar: 492
Pósturaf Zorky » Sun 24. Nóv 2013 17:37
fer á 8000 kr :)
eða skifti á Beyond Two Souls
Zorky
Póstar: 492
Re: [TS]Samsung ST90 14.2 MP 7000kr
Pósturaf Zorky » Mið 27. Nóv 2013 13:09
Fer á 7.000kr tek hugsanelaga skiftum á eithverju sniðugu :þ
Zorky
Póstar: 492
Re: [TS]Samsung ST90 14.2 MP 6000kr
Pósturaf Zorky » Fös 29. Nóv 2013 12:27
6.000kr bara í dag !
Zorky
Póstar: 492
Re: [TS]Samsung ST90 14.2 MP 5000kr
Pósturaf Zorky » Lau 30. Nóv 2013 13:44
Fer á 5.000kr verð á ferðinni eftir get komið með hana til þín :)
